bb 440 oil pump o ring ?
flathead31coupe
indianapolis indiana
I have a fel pro timing cover gasket set that has the oil pump base gasket and the o ring for the tube that goes in the block, ? is it came with a round o ring and a flat o ring witch do I use....
If the flat O ring is around 2" in diameter, that's the inside oil pump seal.
