flathead31coupe
I have a fel pro timing cover gasket set that has the oil pump base gasket and the o ring for the tube that goes in the block, ? is it came with a round o ring and a flat o ring witch do I use....
its about a 1/2'' its fits in the groove around the part that goes in the block....If the flat O ring is around 2" in diameter, that's the inside oil pump seal.
thanks do I use the flat type o ring or the round type o ring,............u got errrrr............kim..........
