[SOLD] BB .474 purple shaft, lifters and timing set. NEW
69B3GT
Active Member
Riverside, CA
Rating - 0%
0   0   0
Big Block .474 purple shaft NEW never been in a motor, 16 brand new summit brand lifters and summit brand timing set for big block.
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-6,000
Intake Duration at 050 inch Lift: 238
Exhaust Duration at 050 inch Lift: 238
Duration at 050 inch Lift: 238 int./238 exh.
Advertised Intake Duration: 280
Advertised Exhaust Duration: 280
Advertised Duration: 280 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.474 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.474 in.
Valve Lift with Factory Rocker Arm Ratio: 0.474 int./0.474 exh.
Lobe Separation (degrees): 110
Camshaft Gear Attachment: 1-bolt
Lifter part number SUM-HT2011
Timing set SUM-G6604-9 (has built in retard and advance of -8 +8 degrees in 2 degree incraments)
Everything from summit will run you about 275 through SummitRacing
ASKING 175 PLUS shipping. Or, make an offer. worst I will do is say no. These parts are all brand new, never been in, or on an engine.
Thanks, Chris.
