BB Valiant Suspension Setup for Drag
In your last video, the car is still not leaving evenly in the front. Unfortunately CalTracs are a true learning experience, keep a written log of each change you make and don't make big changes. Also, your rear tires may be spinning on the wheels you might want to look into putting bead screws in the inner and outer lips of the wheels. My car actually spun one of the slicks off of the bead years ago before I put screws in the wheels.
Thanks a lot. My tyres are skrewed in the wheels. That are weld Racing.
Cal Tracs are with a little gap this Weekend. I think to that this could be much better. But Its a lot try and error
@mohni, yes it is. On our stock eliminator Dakota, we installed CalTracs before it was mandated that we install a roll cage and got it all sorted out making the truck leave with about 4" of daylight under the wheels. We installed the roll cage and that stiffened the truck up, so we had to start all over again with the adjustments. It took us a total of three months combined pre roll cage and post roll cage. Good luck, keep sneaking up on it you'll get it set up like you want.
