Bell to block alignment
highflyer
oakley ,cal
There are pins used to aligne motor to bell,but i lost mine and need some help please..does anyone have a pic or can tell me which pins and size are used to align these parts..ill be bolting these together tonite,if i can..as always ,thanks for your help..j
I think you can get the pins from Dorman. They are called alignment dowels. If you have a local machine shop they should have source for them.
Any parts house should have straight ones. After you've checked the lateral runout you may find you need the offset ones to get it dialed in. It's a common problem, even with a stock bell housing, and virtually a given with an aftermarket bell.
Couldn't find them in a quick search of their current on line catalog, but Mother Mopar used to sell a set of six offset alignment dowels and listed them in the Mopar Performance catalog,
a pair each of .007, .014, .021 offsets
part # P4120383
