[Found!] bellhousing
It may be possible to do that with a big block transmission?
But the bolt pattern is different on the small block transmissions.
I have a Bell, it it small block OD. It has been bead blasted and has a weld repair around the shifter fork hole. It is the later (better?) Ball stud fork pivot style and comes with a new clutch fork. $65 plus the ride. Will try to find some pictures.
Would you also post part # with pics? Thanks, Al
Here you go, all threads and holes are good.
