I'll take a couple of pictures for you. Have to get the car up in the air to show it properly of course. I'm leaving for Phoenix in a couple of days so it might have to wait until I get back. The rack is a Total Control Products piece. You can see it on their website. The rack uses a separate bolt on drag link, and mine has tabs that locate the inner pivots above the actual rack, if that makes any sense. That means that the rack mounts below the pan, but the inner pivots are actually located upward just the same as the stock Mopar drag link does. These racks were designed by Chris Alston Chassis people specifically for early Mustangs, but it's possible to make them work for rear steer/torsion bar applications. If you look on their site; look at the model they designate for big block application, and you'll quickly see what I mean about the pivot tabs. It's a very heavy duty piece; much more so than any OEM type rack, and also has the correct ratio to work with the long steering knuckle arms that are found on the old style worm and sector systems like our cars. On my Dart it's only 3 turns lock to lock and I have a slightly smaller turning circle than stock. I will post some pictures though.
