Best ET
11.63 113.28 H/SA 3640 pounds and a 340 bub Whitaker built
Man, I haven't heard his name in 30+yrs. When I was young back in Maryland, his M/P mid 60's small block Chevy II was the nastiest, most free revving engine I'd ever heard. I'm Pretty sure I saw him run a B/SR back then also. Absolutely awesome...:thumleft:
11.53 at 118.5 mph. Low block 500 stroker torque monster with 3.55 gears and running through closed exhaust. That's as fast as I can go without adding a roll bar, so just some fine tuning now.
1972 duster, 340 , stock intake, T.Q. carb,8.5 cr, stock heads,1.88 & 1.60 precise 3 angle valve grind. jerico trans, 5.57 dana 60, 9x30 slicks, soft loc clutch.3345#, best is11.21 @ 117, 24. calvert style bars.
Nice! :thumbrig:
Well done!
220 inch outlaw racing built rear engine rail. 500 stroker B1 head 440, 2spd glide, 3.55 narrowed dana 60. Run mostly super comp and brackets when I'm home in Florida. Home town track Bradenton Motorsports Park.
My 383 / 727 / 8.25 (4.10's) Duster went 13.10 @ 106mph with 1.97 60ft times on 275/60/15 ET Radials in street trim thru full exhaust. Gotta sort out the rear and get those 60ft times down before I put a 100 shot of gas thru it..
70 Dart, loaded with bondo running a mis-matched 360 with one J head and one X head, 904 trans and 8 3/4 rear with 3.91 gears and super stock springs..255/60/15 mickey drag radials...12.60 with 1.6 60 foot times at 106 mph
Best time on horsepower so far is 8.66@153mph in the 1/4 running leaf springs and a 10.5 slick
69 Dart, 3320, pump gas street/strip small block, 6.44 @ 107.10.
Well don't laugh. She's a work in progress. Woke up after sitting around doing nothing and no love or maintenance for 15 years. Below is all on the same run. After this run it vapor locked the next 2 runs so I went home. These are the best times this Scamp has ever seen. Trying to achieve a 13.999 on 24" tires, the original 14" wheels.
RT: 0.017
60': 2.181
330': 6.033
1/8 ET: 9.178
1/8 Trap: 78.00
1000': 11.895
1/4 ET: 14.179
1/4 Trap: 99.01
TALK ABOUT FREE REVING. I GOT A BUDDIE THAT USED TO RACE S/STOCK / NHRA , HE WOULD SIDE STEP THE CLUTCH AT 8600-9600
IN A SBC, I WOULD GRIMMACE EVERY TIME HE PULLED UP TO THE LINE !! Guess he knew what he was doing, he held his record 18 times over the years !
Our fastest NA Mopar>
1968 Barracuda f/back, 540 all ally wedge on alky, Rons Toilet, -1's GRP, etc., 8.66@153 currently.
Back in 1987, '71 340 Cuda s/strip car, approx 3550 with me>
Stock motor, 2.02 heads, no porting
Holley Strip dom, 850DP
MP .271@.050 purple solid ft.
1.75" race hdrs.
fmvb 727, 10" TA 4200 stall
4.30's/10x28's
stock l/springs clamped, P/snubber
best 12.39@108 NA
