Best Fan
MP's viscous is best hands down bar none.
Got one for $75.00 shipped if you're interested.
What makes these fans so different than a regular clutch fan?
The only difference I see is the blades are spread apart in a odd manner.
Anyone know?
There are two types of fan clutches, thermal and centrifugal.
Chuck
What is the viscous fan thermal or centrifugal?
What is the main reason to convert to a viscous fan? CFM? Horsepower?
I am just wondering what makes the viscous fan so viscous? LOL.
The MP viscous fan allow the engine to run at a higher rpm than the fan
letting it slip at high speed which helps not take as much hp to run as a
fixed fan other benefits are better rpm (quicker) and reduced engine noise as
speed
speed
Thanks.
Just dosen't sound like it's worth the amount of money they want for it. Not that much difference from a regular stock clutch fan. If someone had a fixed fan and wanted a clutch type then it would be worth it seems.
