best fiuld to use
Dennis Gerard
Florida/tenn
What is the best fluid to use in the motor for the top, got my junk yard motor for $23.00 and now waiting on some hoses to come it, found new ones on Craigslist for $25.00 and the ride , so going to need fluid now...
My oe has a clear fluid from 1967. Check your fsm for recomendation.
I'm pretty sure basic 20W hydraulic oil. Check OEM manuals. ATF would stain and stink if it ever leaked.
1969 Dodge FSM
RESERVOlR
DO NOT add fluid to a reservoir until it is installed in its normal position in the vehicle. Adding fluid to the reservoir in a position other than its normal installed position does not allow for fluid expansion and damage to the reservoir may result.
Measure fluid level only when top is lowered. After filling reservoir, raise and lower top several times to expel air that may be trapped in system.
Insufficient fluid in the system may cause slow raising or noise in the pump and motor. Measure fluid level and if low, look for a leak due to a broken line or a loose connection. Fill reservoir (use only AQ-ATF Suffix “A” “Dexron” type transmission fluid).
Does trans fluid have friction modifiers for the clutch plates????? And if so whould that harm non transmission hydrolics ????
What about clear PS fluid?
