Best guess on 434" sbm
Would you mind sharing the crank and rod manufacturer? Did you stay with MOPAR specs or go with the smaller rod pins? Thanks, Dan
K1 4.125" crank, callies rods, diamond gas ported pistons. I went with the smaller rod journal, 2.0 I believe.
Thanks! Appreciate the answer. I want to do the same with my 72 360 block. Had the cylinders sonic check and have tons of material left after a .030 clean up bore. Dan
We have used several different programs to see where I'm at with my build. Most programs say i need 633 hp to hit 10.70 in the 1/4.
With the parts that I have going in this 434", I think I will be around 650 hp
It will look good with a 10.60 on the window and the wheels in the air.:burnout:
:supz: that would be awesome if I could pull 10.60's.
With 590-600 ft lbs I should have wheels in the air:burnout:
