best H pattern shifter for drag racing
rgreule
post falls, idaho
whats the best H pattern shifter for drag racing and quick shifts, just trying to get ideas going for my build.. comp plus?
i like the comp plus...BUT, ive never been to the track with one...
hurst used to make a super shifter with a reverse lock out....had a red handle that you push up or down ...to get the shifter into reverse...
I've got a Hurst Super Shifter III in my car. Shifts great. Bought it years ago...not sure if they're still available.
old hurst comp plus shifter
just worn enough that it doesnt lock
but loosse enough thats you can
push the shifter side ways to get in third
biggest rod with tie rod end instead of the crappy loosse OE one
well judging by hursts website and the little research ive dont the supper shifters are no longer available for mopars..
The Super Shifter 3 is the best one there is IMO. They are not available for anything anymore. The shifters are all the same, so if you find one for a chebbie or phord at a good price, snag it. Linkage is easy to make. I got one for my car a while back. I snagged on the cheap.
Can you make a Supershifter work with a console? I'd LOVE to have one!
I'm pretty sure you can. Hurst Comp Plus shifters came stock in Mopars and the mechanism is about the same as the Super Shifter in terms of size so I would think so. The only possible thing to work around would be the reverse lock out lever if so equipped, but that wouldn't be bad.
Description
COMPETITION/PLUS & STREET SUPER/SHIFTER, 1957-1962 Corvette with BorgWarner T-10
BORG-WARNER T-10, GM AS-3 has 9 bolt curved bottom side cover
Competition/Plus
•Chevrolet CORVETTE '57-'62, All, BW T-10 Trans (Trans Code 410)
Street Super/Shifter
•MUNCIE (Trans Code 451, 452, 453)
•BW T-10 (Trans Code 410)
•RICHMOND/BW SUPER T-10 (Trans Code 454)
•SAGINAW (Trans Code 441)
•NEW PROCESS (Trans Code 421)
•FORD T & C (Trans Code 432 - 433)
Fits model years 1957, 1958, 1959, 1960, 1961, 1962
See transmission ID charts here.
NOTE: Street Super/Shifters are not vehicle specific. They will fit the transmissions listed, but will not fit stock consoles and often require minor floor pan modification for installation.
PART NUMBER 3917535
Details
Part Number:
3917535
Price: $291.56
Super Shifter III.4 1/2" throws and spring loaded 2nd to 3rd shift.Set up right you can shift as good as Ronnie Sox.Also has stop bolts so you don't overshift and break the synchro blocks.
