First time for me bolting 904 transmission to 318
Bought the motor complete with mild rebuild, and got the transmission from a trusted member reported as running perfect on recent refresh with stock torque converter.
I don't know much about the cam other than it's .480 lift hemi grind. The bottom is stock,
The heads are 318 heads with 1.88/1.6 valves, casting # is 3769973 , they are ported nice and gasket matched to the intake. It is a performer with a 600 CFM Holley on it.
I have posted here a number of times asking about the torque converter and a got what seamed like 100 different opinions. The one fairly consistent thing I could gather was that a high stall 273-318 stock converter would be the best to use fro a mild build cruiser.
So since I just sent the car out to the body shop for final body work and paint, I want to assemble the motor and trans and have it ready to go in the car when I get it back.
I have the complete transmission and the complete motor with a box full of bolts, motor mounts and cross member, however I could use some guidance as to what to do, and what not to do.
Thank you
Thank you
