hellion_locdogg
Slant Sickness
So what have you used and what works best?
,Cliff
,Cliff
Ditto on the silver paint, Article on steel shims said Mopar went away from Steel shims because they could rust and blow out by the water passages without the proper rust inhibitors. Also said they needed a sealer, but The only 2 I ever worked with were taken off a virgin 273 Commando motor. Replaced with a .044 Fel-Pro blue one and the ports had to be matched afterwords.Copper Coat works well. I have heard of Silver metalic paint also.
Mad Dart said:That fire was exactly right above my house on the top of the ridge! They got it under control quickly though!
