best shocks and suspension front and rear for a 1972 dart
Wondering whats best for my dart it has a sb in it.
That is going to depend a lot on what you are planning on doing with the car. shocks for autocross/road course racing will be a lot different than shocks for drag racing or 'cruising'. Have you upgraded your torsion bars to stiffer ones? If so, you'll need to get a firmer shock to match them.. tell us a bit about what your plans are with the car :)
for a cruiser, just use .910 bars, kyb shocks, and a sway bar from hellwig. rebuild the front end, use moog parts for the idler arm, pitman arm, inner & outer tie rod ends and lower control arm bushings. if ya want to use poly grahite upper control arm and strut rod bushings, that will be okay as well.
