Hallzy
Yanked from the trees where it's been sitting for 30 years.
Now that’s a SWINGER!lol.RjYanked from the trees where it's been sitting for 30 years.
That's a lot of work for a parts carLooks to be a 74 model. Can't see the front good enough to see if it's Dodge or Plymouth. Disc brakes.
That's not much work at all took a half hour from the time I pulled up until it was on the trailer headed home. It would have taken a full day to cut a path and drag it outThat's a lot of work for a parts car
Yes its a 74 I don't need much from it but the quarters are good doors and glass are good trunk lid is good I figure better to patch mine with real oem steel than thin overpriced junkLooks to be a 74 model. Can't see the front good enough to see if it's Dodge or Plymouth. Disc brakes.
Yeah we have 5 of them at the shop I just happened to have this one out right in that area today so I finished a paid job and then just popped in and pulled this one out. There's a couple more in there yet.i guess that depends on what you are using to cut a path and drag it with
but im guessing if you got access to cranes like that, you may have something else up your sleeve
Lol no that would have taken too long just hooked the lifting chains to the k member and the rear bumperThat's cool as heck! What did you hook the back slings to, bolts thru the bumper bracket holes? I pulled a 70 Roadrunner out of a creek one time with a big digger derrick truck from work, and set it down on my trailer just like you did.
