jos51700
Green Bearing thread connoisseur
A couple years ago, my Valiant lost a battle between a tree and gravity.
I need to get a windshield in this car to get the city off my nuts. Obviously, I don't care if it leaks, it's been leaking since Nirvana was still a band.
Getting the old windshield out is easy. I think I have a line on a not-busted-to-bits replacement. I'm thinking I can just push up on the roof from the cross-member with a jack to 'pop' the roof back to close. Close is all it needs to be, I'll sort it out later if I ever get to this project. I just don't know if I should try to push in the center of the crease, which I've heard is terrible but with a wood piece in there might raise it back up, or should I try pushing on either side to slowly work it out? I've heard the second method referred to as 'bumping'.
Thanks to all you Mo-magicians that know how to sort these things out!
