Best wiring harness for 73 Duster
Discussion in 'Electrical and Ignition' started by Fred Menna, Jun 12, 2018.
  1. Fred Menna
    Fred Menna Member
    13
    5
    May 18, 2018
    N. Scituate, Rhode Island 02857
    Local Time:
    1:47 AM
    Who makes the best harness? Ease of installation?
  2. General Disarray
    General Disarray Well-Known Member
    164
    117
    May 4, 2018
    South Park
    Local Time:
    11:47 PM
    Ease of installation is relative, depneding on your skills and patience.
    M&H makes really good, factory stuff, sold only through Year One, though. If you want factory replacement, this is it.
    Ron Francis has a couple of Mopar kits. I have used RF for racing applications, good quality, good directions and tech support. Probably my second pick.
    American Autowire makes really good stuff, too, but not specifically for A-bodies.
    Painless has a generic Mopar kit, good quality. Doesn't usually have all connectors and sockets. Probably my third pick.
    I'm sure there are others, but I've never used them.
    Make sure you compare kits, understand what they include and what they don't. Make sure you can find the items they don't come with.
    Good luck.
  3. inertia
    inertia Well-Known Member
    3,038
    389
    Feb 4, 2011
    Victoria B.C. Canada
    View My Photos
    Local Time:
    10:47 PM
  4. QuickDart360
    QuickDart360 Well-Known Member
    712
    177
    Apr 5, 2014
    San Antonio
    Local Time:
    12:47 AM
    Evans wiring has nice harnesses. They are less expensive than Year One in some cases. They have been around a long time. I bought a harness and it is a nice piece.
  5. mpd12150
    mpd12150 Well-Known Member
    170
    34
    Mar 13, 2016
    Bismarck, ND
    Local Time:
    12:47 AM
    I was at a vendor booth at Mopar in the Park in Minnesota over the first of June weekend and saw a factory style harness. I asked who made it and they said they got it through Year One. This vendor was pretty high priced so I looked at the Year One kit. It looked very nice so I ordered it.
    I saved about $150 on the 3 kits, under hood and engine, dash and taillight harnesses plus I had a 30% off code. I ordered all 3 harnesses and the under dash firewall insulation with shipping and it was $738.
    Now, if you do not want to pay that and are looking for a harness, I have a Ron Francis harness that you have to pull wires and make ends for that I will not be using and will sell.
  6. mpd12150
    170
    34
    Mar 13, 2016
    Bismarck, ND
    Local Time:
    12:47 AM
    By the way, the harness from Year One is pretty awesome. Very much like original stuff!!
  7. 89on35s
    89on35s Inferno Red Duster FABO Gold Member
    1,185
    675
    May 11, 2006
    Martensville Sask. Can.
    View My Photos
    Local Time:
    12:47 AM
    If you can get a FSM (yours is available free somewhere online) you can do a lot of restoration to a factory harness for little money and it's not difficult. Mine worked out well, and since mine was a 74, I removed the seatbelt interlock crap to simplify it a little.
    Cley
  8. Howard1784
    Howard1784 Well-Known Member
    559
    49
    Nov 3, 2009
    Northern Virginia
    Local Time:
    1:47 AM
    I bought a year one (made by M & H) for a 73 Duster. It was a little different than the original. I would send the old harness or photos to make sure they replicate the replacement. Mine was non a/c etc. etc, but needed some rewiring unfortunately. A guy I talked to for the same mode/year was a direct replacement.
    My door jamb light wiring did not match as an example
  9. Tadams
    Tadams Tadams FABO Gold Member
    3,532
    1382
    Jun 13, 2008
    nc
    View My Photos
    Local Time:
    1:47 AM
    How do you do the restoration of the harness. I'm at the stage of making a decision of purchase or restoring mine.
    Thanks
  10. General Disarray
    164
    117
    May 4, 2018
    South Park
    Local Time:
    11:47 PM
  11. 89on35s
    1,185
    675
    May 11, 2006
    View My Photos
    Local Time:
    12:47 AM
    Unwrap the whole thing and follow through wire by wire replace any bad wires or splices. Redo any bad connectors in the plugs. Get some Packard 56 connectors (I got mine off E-bay) and just make it like new again. Learn how to solder and splice on You Tube. Most important thing you can do is remove it all. Don't try and do it in the car. I made a scroll out of all the wiring drawings in the FSM to make it easier to follow.
    Cley
  12. Tadams
    3,532
    1382
    Jun 13, 2008
    nc
    View My Photos
    Local Time:
    1:47 AM
    Thanks. My car is completely disassembled. Hope to paint the engine compartment and reinstall the engine soon
  13. General Disarray
    164
    117
    May 4, 2018
    South Park
    Local Time:
    11:47 PM
    Personally, I wouldn't put 45 year old wiring back in, especially if the car is completely disassembled. You have the space to freely run the wiring. Just my perspective.
    • Thanks! Thanks! x 1
    • fishfly
      fishfly Well-Known Member
      58
      13
      Jul 23, 2017
      usa
      Local Time:
      1:47 AM
      I wouldn't bother restoring a 40+ year old harness. By "restoring", I mean going through all the work of pulling out and inspecting the old harness and splicing in new sections where any of the wires look bad. The problem with that is that with wires this old, they can look ok on the outside, but the inside is corroded. Then problems arise later and all the work was for naught. Also, splicing in sections creates points of potential failure/problems. You would need to sand down every blade/connector to make sure every square millimeter is making new/shiny metal contact to replicate the effectiveness of new connectors. You would also need to take apart the bulkhead connector and clean those contacts. I didn't want to go through all that trouble of restoring for a subpar/old system with as much (probably more) work than installing a new and updated aftermarket setup. I went with ron francis and happy with it. Good instructions and support. Install was easy-just took time. I completed it in about 2 weeks working on it with my schedule. You are also given a color coded diagram for the entire vehicle. Now you could use your old harness as a guide to replicate lengths/colors and gages to build your new one. I didn't have the time for that and there is no way I would pay upwards of 1k to purchase a kit that claims to be an exact replica.
    • 89on35s
      1,185
      675
      May 11, 2006
      View My Photos
      Local Time:
      12:47 AM
      Others experiences may differ, but the 2 harnesses I had were in amazingly nice shape. Some issues at the bulkhead connector that were easily fixed and the only other issues I found were caused by prior butchery. The wires themselves, even the underhood ones were in nice shape.
      Cley
      • Agree Agree x 1
      • dustyaman
        dustyaman Well-Known Member
        77
        7
        Apr 23, 2012
        conway ar
        View My Photos
        Local Time:
        12:47 AM
        Just bought a Ron Francis retro kit waiting for it to be delivered today actually. I will put some pics up when I get it
      • dustyaman
        77
        7
        Apr 23, 2012
        conway ar
        View My Photos
        Local Time:
        12:47 AM
        Here is the Ron Francis retro wiring harness
      • dustyaman
        77
        7
        Apr 23, 2012
        conway ar
        View My Photos
        Local Time:
        12:47 AM
        The one thing I’m upset with with this Ron Francis wiring is they don’t have a simple plug for the original gauge cluster
      • 64ragtop
        64ragtop Well-Known Member
        997
        40
        Jan 14, 2005
        South Austin, Texas
        View My Photos
        Local Time:
        12:47 AM
      • 64ragtop
        997
        40
        Jan 14, 2005
        South Austin, Texas
        View My Photos
        Local Time:
        12:47 AM
        Ma Mopar didn't make that easy! The GOOD news is that those plugs were the same for many years. Not that hard to reconstruct from salvaged 12" (suggestion) wire ends.
      • dustyaman
        77
        7
        Apr 23, 2012
        conway ar
        View My Photos
        Local Time:
        12:47 AM
        Do you know what each wire color goes to on that plug. That would make it a heck of a lot easier. That’s why I kept my old harness for something like this.
      • General Disarray
        164
        117
        May 4, 2018
        South Park
        Local Time:
        11:47 PM
        For my project, since I plan to replace everything, I am going with American Autowire Classic Update for Modified Restoration, not OEM. The kit has all the bulb sockets and wiring for aftermarket A/C, gauges, fuel injection, etc. The only way to describe what many previous owners have done to the wiring is - F'd Up. Must have had a sale on red and yellow wire at Home Depot. Anyway, if you plan some modern updates, this kit may be worth a look.
