Bezel Tool
coalman
Texas
Anyone know where you can get a C-3824 Tool, or how to make one??? Thanks
I'm not sure which tool you're referring to, just guessing....
Needle nose pliers will work for antenna bezels, remote mirror bezels, etc.
Try finding John Rivinius on Facebook or type in" Mopar switch bezel tool " in the search box. tmm
I am using needle nose pliers right now, they slip out a lot and scratch the bezel .. I thought there might be something better out there. Thanks to all of you for your input....
You can try putting some tape on the end of a short, flat blade screwdriver & tap it with a small hammer.
Which bezel are you trying to remove?
They are all out, instrument cluster is sitting on table....
Found some Bezel tools on "E" Bay this morning. Ordered one, hope it works...
Did it work? Where are you located? Anywhere near Abilene?
Here's a trick... No tools necessary.
Reach behind the dash, and twist the switch side to side with one hand, while you twist the bezel with the other.
Works every time to loosen as well as tighten.
