[SOLD] Big Block adjustable rockers, pushrods, springs, retainers
physixx
Edison, NJ
I have for sale a big block solid lifter valve train setup. The rocker arms look like the MP setup (but can’t be sure) and include the shafts and attaching hardware. The pushrods are the 3/8” cup/ball design for use with solid lifters and the adjustable rocker setup. I’m also including the dual valve springs that came off the heads of the engine that these parts were installed on. I’m not sure who made the springs but the cam that was in the engine was a Lunati 43709LUN grind with .518/.540 lift. The springs have an OD of 1.516”, ID of the outer spring is 1.080” and the ID of the inner spring is .725”. The springs also have a damper between the inner and outer springs. In addition, I am including the steel spring retainers. This setup ran very well with the cam until the cam wiped out. Everything has been cleaned and in excellent shape. I’d like to get $250 for the entire setup plus the shipping.
Ken
Edison, NJ
