Big block center link / Idle arm /187 pan pix
440BBRAM
Member
Ga
Does anyone have or can anyone take a picture of the idle arm /center link / 187 oil pan of their Big Block installation? My center link strikes the pan on pass side and the idle arm is no where near the pan indentation. All new bushing, tie rod ends, Pittman arm, idle arm and new engine mounts (Schumacher). 70 Dart. Thanks
Cant take pics tonight but do you have the drop center link or is it completely straight. Also you can move the motor a bit like I had to do.
All 1970 suspension components. Original /6 - V8 center link. I did this swap in the early 80's. No engine movement/setback required. Life event (wife & kids)took me down different path. Sold everything. Unless something has changed, I believe I have the same set up. Push comes to shove, ill pull the pan and notch it. Thanks
