Big block distributor shaft length?
slmiller243
Active Member
We have a 383 with Mopar electronic ignition system and Mopar performance distributor. We were having some problems with the distributor and decided to go back to a stock distributor. The shaft on the stock distributor is 3 1/2" which is supposed to be correct but it is too long. The Mopar performance distributor shaft length is 2 1/2".
Are there different length distributor shafts or am I missing something?
I know that B and RB use different length shafts and they sell adapter spacers to use an RB length one in a B motor
sounds like you are trying to use a distributor from a 440 which is a RB. You can get a bushing spacer to make it work though, hope this helps Joe
For a 383/400 the shaft length from the end of the shaft to the shoulder of the dizzy housing that locates against the block should be 3 1/2" long. trust me, the 440 will be almost 3/4 of an inch longer. Also make sure that your oil pump drive gear is all the way down and not riding up on the cam gear.
What problems were you having ? 2 1/2" sounds a bit short , shouldn't it be 3 1/2" for a 383 ?
