Big Block Exhaust
66VALIANT
ROCKDALE IL
HEY i havent seen much for big block exhaust for an early a body its a 66 valiant any one been through this or got any ideas its a 4 spped so i got 2 get around linkage to. thanks
Your gonna have to make it yourself from pre-bent mandrel pipes, or crush pipe. Or spend some big money from a muffler shop. Most likely they with use the crush-pipe bender. Call around to different shops as some are going the mandrel bender way as the call for it has risen. Good luck. BigBlock in a early A is what some see as extreme as there is no space with a smallblock let alone a bigblock.
You can run fenderwells easily, or make custom headers. I've seen underchassis headers on a 440 in a 66 barracuda done very nicely.
