sledger46
Hello all,
I decided to try to see if the all-in-one GM style HEI would fit on my 360 in a 67 Dart. The word on the street was it didn't fit or it is extremely tight. In my case it is extremely tight.
In order to get some more room I moved the engine forward. I slotted the engine mount perches and the transmission mount where it bolts to the transmission.
The result was the clearance I was trying to achieve:
In order to hook up power to the new HEI distributor you need to tie IGN1 and IGN2 together so you have voltage during crank and run. I simply moved my tach wire from the old distributor to the terminal on the new HEI distributor. For plug wires I used wires for a 89 Mustang with a 5.0L as they have the correct connectors for the terminals on the cap and also have 45 degree boots (this really helps on #5 and #7 with the header tube).
There was actually room to route spark plug wires behind the cap. The wires look close to the headers but are actually several inches away. I still need to come up with wire looms to clean up the routing.
