dartnabout FABO Gold Member FABO Gold Member Joined Aug 27, 2007 Messages 16,421 Reaction score 11,787 Location Central PA Aug 23, 2016 #1 Is a truck 727 automatic transmission the same as a car other than the tail shaft? Is the gearing different in a truck?
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,145 Reaction score 8,372 Location Kindersley, Saskatchewan, Aug 26, 2016 #2 ...........There are minor differences in the trannys.....some trucks and vans also have the long tail shaft same as a car.........kim..........short trannys came in club cab trucks.......
B Bulldozer free ice cream sandwiches Joined Oct 16, 2011 Messages 14,985 Reaction score 2,396 Location behind the wheel Aug 26, 2016 #3 the trans I'm using now came in a 68 long bed dodge 2 wd pick em up. it's a regular 35" 727
AJ/FormS 68 Formua-S fastback clone 367/A833/GVod/3.55s Joined Jan 19, 2014 Messages 24,946 Reaction score 12,297 Location South-Central Manitoba,Canada, 900ftelevation Aug 26, 2016 #4 The one in my 84-D100 is same gearing as car; and long shaft.
YY1 Well-Known Member Joined Oct 11, 2011 Messages 11,773 Reaction score 8,350 Location FL Aug 26, 2016 #5 Isn't there a truck/heavy duty version that has a 4 gear planetary set instead of the usual 3 gear set?
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,145 Reaction score 8,372 Location Kindersley, Saskatchewan, Aug 26, 2016 #6 Yes in the 3/4 and 1 ton big block applications. Mostly 440s
