SincerePuppet
Member
Posted a while back about getting the right trans fluid but due to a whole lot life things getting in the way, I'm only just now getting around to doing the work. Ran into yet another potential problem today though, my replacement filter is slightly bigger than the stock one.
Is this an issue? Seems to be no problem with the clearance/fit of it in the trans itself and I don't see why it would be, but figured I'd ask before putting the trans cover back on and filling her up with new fluid.
Attached are pictures of the original and the replacement (might not help much, but hopefully you get an idea of the size difference). Hope you all don't mind the newbie question. Cheers.
Old filter:
Replacement:
Old filter:
Replacement:
