Im pretty sure the megasquirt is nothing to do with the ign,other than timing pulses to the injectors. However the megaquirt ii and iii can both control ign curves etc.
I just got back from the Megasquirt site. According to this article:
http://www.diyautotune.com/tech_articles/how_to_megasquirt_your_vintage_mopar_engine.htm
"Using the MegaSquirt-I (MSnS-E) with Direct Coil Control"
You can pretty much use ANY Mopar dist. A partial quote from the article:
"Chrysler built several different variations on their "classic" VR type distributor, not including the number of different advance curves:
1. One VR sensor, with mechanical and vacuum advance
2. Two VR sensors, with mechanical and vacuum advance
3. Two VR sensors, with no advance mechanism
4. One VR sensor, with no advance mechanism
Most of the distributors you will see are either of the first or fourth kind, with the remaining two being seldom seen designs used with the earliest versions of the Lean Burn system. When setting up Megasquirt on your Mopar, you can use any of these four types. The most straightforward is the fourth type, with just one VR sensor and no advance mechanism. If your distributor has an advance mechanism, you must lock out the mechanical advance and disconnect the vacuum advance. If there are two VR sensors, simply ignore the second one."
