RustyRatRod
Caput villa stultus
or a pair of turbos and a blow thru carb to keep it under the hood?
Under the hood? Where's the fun in THAT?
yeah as i wrote it i thought ''says he with a tunnel ram and 2 holleys through his hood'' lol.Under the hood? Where's the fun in THAT?
Oh ok thanks good to know. Idk what I'm gonna do yet. Im gonna start by measuring the piston height i may end up having the heads and deck milled and remove the oring or I may just get some copper gaskets and run em.I don't know... when redone with 1008's the orings were removed by the engine builder. I had them take a skim cut on the heads and block and now it's about 14-1 compression.
Tunnel ram is what I was thinking too until RRR said blower and that sounds awesome too but tbh im not sure i can afford either! This motor is gonna be for my 74 challenger and I was thinking about doing like a 80s themed muscle car wide tires, 80s style rims jacked up in the back with a dual quad tunnel ram sticking out of the hood, but a 6-71 blower sounds even better lolyeah as i wrote it i thought ''says he with a tunnel ram and 2 holleys through his hood'' lol.
My engine ran fine with the oring grooves intact using FelPro 1008 gaskets @ 13-1.I'm almost 100% certain you need to use copper gaskets with O-rings. Call SCE and find out.
