gzig5
If you can, grind a 1/2" pilot diameter on the tip of the drill. That rides down the bore of the drilled hole to keep it in line. You'll have to touch up the front of the cutting edge. Doing the pilot in a lathe is easy, but it can be done by spinning the bit in a drill and taking a grinder to it. Ends up looking like this. Piloted Double Margin Drills
Also, most drill presses have a machined surface on the base so you can set something tall on the base and drill it. If your head doesn't adjust down, you might need to block it up or build a simple support table from 2x4's.
