thank you@Johnny Mac Maybe Johnny can assist, he works at Blueprint and is a member here..
ok
Assuming your converter is neutral balanced, as most aftermarket are, you need this flexplate. Chrysler SB Steel SFI Flex Plate - LA 360 SB EXTERNAL BALANCE 727 and 904 - Chrysler CompatibleHey guys, got a hold of a 2015 Blueprint 408 and need to find out if l need an externally balanced flexplate. Any info would be great, thanks.
thank you J MACAssuming your converter is neutral balanced, as most aftermarket are, you need this flexplate. Chrysler SB Steel SFI Flex Plate - LA 360 SB EXTERNAL BALANCE 727 and 904 - Chrysler Compatible
anything wrong with using a knockoff?thank you J MAC
anything wrong with using a knockoff?Assuming your converter is neutral balanced, as most aftermarket are, you need this flexplate. Chrysler SB Steel SFI Flex Plate - LA 360 SB EXTERNAL BALANCE 727 and 904 - Chrysler Compatible
I'm unsure anybody makes one. But I don't think anything would be wrong with it as long as it was the same style. You should verify 100% that's what you need though.anything wrong with using a knockoff?
Do not forget the externally balanced Harmonic Balancer and if not you will have one heck of a vibration.Assuming your converter is neutral balanced, as most aftermarket are, you need this flexplate. Chrysler SB Steel SFI Flex Plate - LA 360 SB EXTERNAL BALANCE 727 and 904 - Chrysler Compatible
got itDo not forget the externally balanced Harmonic Balancer and if not you will have one heck of a vibration.
DODGE Summit Racing SUM-G124SFI Summit Racing™ SFI-Approved Flexplates | Summit RacingI'm unsure anybody makes one. But I don't think anything would be wrong with it as long as it was the same style. You should verify 100% that's what you need though.
looks darn closeI'm unsure anybody makes one. But I don't think anything would be wrong with it as long as it was the same style. You should verify 100% that's what you need though.
Using a flexplate made by "lord knows who" would be a really poor $90 to try and save in my opinion, when the manufacturer that makes the engine, sells one balanced and checked, again to the correct spec. On a new engine install, if you find a vibration, I would sure like to know I'm not pursuing a "store brand" to help diagnose. Not dogging any reseller or WD, but just my opinion.anything wrong with using a knockoff?
Harmonic Balancer - Chrysler Compatible - 273, 318, 340, 360 and 408Do not forget the externally balanced Harmonic Balancer and if not you will have one heck of a vibration.
Thats a pretty old engine. Who knows what it's been through. May have been internally balanced by now. What does the damper look like?Hey guys, got a hold of a 2015 Blueprint 408 and need to find out if l need an externally balanced flexplate. Any info would be great, thanks.
