Bolt Pattern??
Small Block
West Plains, Mo.
I've just picked up a 73 Duster and i'm thinking the bolt pattern changed in 73 to the large pattern. 72 and earlier was small pattern. If i'm right i'll be able to get the torque thrust is the BBP. Am i right??? This is a /6 car with drum brakes.
drum brakes had small bolt pattern for sure, I owned a 73 scamp that was that way.
If you cruise e-Bay you'll find SBP Torque Thrust's from time to time. They're out there....
