Twisted-72
How can I find out what day my car was born on ? Door sticker has 10 - 71 and the build sheet tells me the time of day 22:12, but I can't find the day.
SO/PO number on rad support? Found out mine was built April fools day! 4-1-65 decoded...
Look on your fender tag, my 70' has the estimated build date on the last line near the right. It might be on the second line up. It will be a three digit code. 110 will be Jan 10th.so 1 thru 9 is Jan to Sept. A is oct, B is November,etc. the next two numbers are the date of the month. That date is approximate, It could have been a few days later. That's all we get.How can I find out what day my car was born on ? Door sticker has 10 - 71 and the build sheet tells me the time of day 22:12, but I can't find the day.
It is possible to get close, if not the day. If you have your original build sheet with the Inspectors Initials on it, then that was the day the sheet was put wherever they put it. In 1967 and 68, if you look at the top of the sheet,you have the sequence number, second box is build date, third is theThe SPD on the fender tag is just when the factory "planned" on building the car. Most of the time, the vehicle was NOT built on that day.
Sometime in 72, the door stickers were changed and an MDH code was added to them. My 73 Challenger has an SPD of 927(September 27th) however, the MDH code says 101212.(door sticker says 10-72) The car was built 2 weeks after its SPD.
If you have an earlier 72 or older car without an MDH code on the door sticker, there is no way to know the exact date the car was completed.
