like_A_pike
that's not factory
I need to run cooler when not moving. I understand that smoother idle can be obtained too (which i could use)from getting some neg. pressure from below the throttle plate. The only port in the manifold is connected to the carb however. Can I split that source between the carb and the distributor to achieve my objective?
thanks
thanks
