yellow rose
Overnight Sensation
No dummy. Real cat videos. I ain't hard to entertain.
Like I said...asking for a friend. I know you southern folk have different meanings for different things so I needed a quick clarification.
I think it is 4.10 gear. Don't know tire size.
That’s a 12.669 SLR. I’m at 14.0904 and that’s not enough to move the car very well.
The less power or more weight or both needs more gear to make the car move.
I’d like to be at 15 for my SLR, but that may not be possible.
What transmission do you have? If it is a regular 4 speed 2.66 1st, and you go to the OD 4 speed with 3.09 1st, that will take you from 14.0904 to a 16.3682 SLR.
I think his whole theory was to have the car in 2nd gear for the majority of the run, while spraying about a 300 shot. Sounds like a recipe for disaster, but we shall see! It's a fun journey to watch regardless!
But, with the OD ratios, If you shifted at 7000 (just an example), you would drop to 3783 at the 1-2 shift. The regular 4 speed would drop from 7000 to 5026.
I can think of a few cams and ported head combos that would fit into that OK. A well ported head will carry a small cam a good bit further than normal.But, with the OD ratios, If you shifted at 7000 (just an example), you would drop to 3783 at the 1-2 shift. The regular 4 speed would drop from 7000 to 5026.
