Bought another 340.
AdamR
Big Member
Bethel, CT
I scored a great deal on a 340 off of Dwanye Porter from Porter Racing Heads.
* 1973 340 block
* decked to +.020 deck height(pistons above deck)
* bored .030 over
* Ross flat tops with max weight removal option*** and .927 pin bores
* B&B tool steel wrist pins, 2.500 X .927 X .090 wall(piston and pin 525g)
* OE rods bushed to .927, fully polished, resized, lightened, ARP bolts
* OE steel crank( reground, strokes equalized, indexed)
* Milodon deep pan
* Melling oil pump
* double roller timing set
* Crower 262/265 @ .050, .575/.585 solid lifter cam
* Crower lifters
* ported 587 heads with MP 2.02/1.60 valves, milled for true 11:1 CR
* bronze guides and hardened exhaust seats
* Crower dual springs
* Comp 10deg retainers and machined locks
* Edelbrock Victor intake, gasket matched, mild plenum mods
* Harland Sharp 1.5 roller rockers and HD thick wall shafts
* Crane pushrods
* MP moly coated fuel pump eccentric
* MP OEM replacement 340 damper
* Moroso blue anodized valve covers
*dyno tested at 450HP/400TQ prior to freshening, not fired since reassembly.
motor only has 125 passes on it since new.
Cant wait to get it !
Sounds good! That ought to put some life back into that cuda. So are you still selling your motor?
Make sure you read the comment he left for these.
Good Score.
Your gonna pass me going down the 1320.
It should go real nice with the 904 and converter you have.
Good luck.
I saw the comments and we discussed it. He said to make sure to keep it out of detonation. It wont see enough street miles to worry about other then that and later it will get a 4" crank.
I may still sell it so I can buy a nice set of headers for the new motor but my father asked about it for the 89 Daytona he just brought home so it may go to him. After all he was nice enough to loan me some money for this motor.
duster340 said:
sounds good! that will make your cuda move:)
This moto ran 11.60s in Dwaynes 3500lb 68 Satallite. Sinve he pulled it he freshend the motor did more port work to the heads (260cfm @.500") cleaned up the intake and added another half point of compression. He's going put it back on the dyno and set up my carb for it. He says it will probably make around 470 horse.
Im going to need more gear. He was shifting this thing at 7500rpms :-D
that is one quick 340!
i love the sound of my 340 screaming at 7500rpm, hope you will enjoy it as much as i do!
It looks it to me Mike. I'm gonna repaint it and change the valve covers.
