braided lines question...
mopardude318
Gilroy, Ca
im having a bit of trouble getting my brake lines from the master cylinder to the prop valve, and from the prop vale to the rubber mounted lines on the frame to seal and not leak...ive made new ones, out of new lines and i make nice flares with a hydraulic flaring tool that i have and i know it works good because ive made quite a few flares on other parts where they dont leak....just these one i mentioned (3) are leaking...
i was wondering if it would be a good idea to use a stainless braided line from the master to the prop valve and from the prop. valve to the frame, and frame to calipers...this probably sounds like a lot of flex line to use....do you think i would lose pedal feel and brake performance if i were to use flex line? this will be for a street performance handling car....
what are your thoughts?
