Braided steel brake lines to short? HELP
Mopar85
29 Palms MBC
I have a 73 duster with front disk and bought brake lines from PST and it seems like the lines are to short. has anyone else had trouble with this? I have them installed pointing to the rear coming off the caliper.running to the stock mount point on the frame and when i turned the wheel they barely turn.
Please help
If you are able, return them and contact "http://www.inlinetube.com/" you can pretty much bank on their stuff working, if you have OTHER than stock applications, measure them for optimal length and inline will make them up for you.... you also have a choice in regular brake lines of steel or stainless, by far they are the best I have ever found...they aint cheap but they wont take ya broke either
