[SOLD] Brake Drums
Are the 10" drums the small bolt pattern 1.75" wide drums or??
I've got twenty or so assorted drums on the shelf right now...a little bit of everything. That's why I said in the original post to PM your needs and I'd go through the pile.
Those 10" SBP 1.75 drums are early V8 A Body, correct? I may have one or two. I'll check in the morning.
Tony
They used them up to 72 on A-body 8-3/4's. I don't actually need them Tony so don't check for me. I have seen guys post in the past that do. I thought it may help you sell some if guys knew exactly what you had since there were 3 or 4 different 10" rear drums. Good luck bud
hi ,wish i seenthis post earlier!!!just put a 742 8 3/4 rear under my duster but i need u bolts and the bottom plates,do you have this for sale?also i have the origanol rear (6 cyl car )i guess a 7 1/4 to sell or trade if its worth anything.thanks !!!dan.
I am looking for a right rear brake strut bar and self adjuster arm. Changing out my wheel cylinders today and took of the drum and missing two parts. If you have any idea how to get these, please let me know. I am trying to get this old 66 barracuda moveable.
Thanks, Bobby K.
Hi, looking for a front left sbp - with eft handed threads. 10"
do yo have anything (mine pitted)?
thanks
Ten inch drums have become super scarce this last year or so. Just sold the last pair I had on the shelf, but may have one or two loose ones around here somewhere. I'll dig around and get back to you later if I find anything.
Tony
