B Taylor
My brake lights stopped working. They worked fine last time I had the car out.
I have checked the switch and it is working, I have power from the dual pink wires and when depressed I have power on the other side of switch (white wire) .
From that point I don't have power to the bulbs. Tail lights work, turn signals work.
I looked at the wiring diagram and know the power goes from the white into the Directional signal switch connector then to a Dark green wire to the brake lights.
Anyone have experience with this? Is there a connection in the directional switch that may cause the brake lights not to work?
