[WANTED] Brake Parts ... Front Window Chrome ... Upholstery
Randy Miller
Royal City, Washington State
1967 Dart GT 2 Door Hardtop
I'm looking for the pins that go in the brake wheel cylinders with drum brakes. I ordered new cylinders but they do not come with the pins? (need 8)
Also metal fork that hold the shoes in place for the front brakes. (2 total) When I got the car someone took all the hardware?
Front windshield Chrome pieces.
May be a long shot but also need inside door panels, and rear seat panels. BLACK
Black upholstery seat covers, bucket seats and back bench. I can not get any new ones till July at the earliest!
Thanks
HemiSSDart
Dartus Interuptus
Illinoisy
Do you mean the four corners of the 67 Dart? There are a total of 8 pieces, four plastic/tin pieces and four small stainless corners.
barracudakid
king nc
I have the wheel cylinder pins,brake bars and windshield trim if you are switching to stainless
Joey4speed
Coastal NC
This may help.
So, on the drum brakes, you're looking for 8 wheel cylinder plungers, #22:
What "metal fork" are you referring to?
Update: looks like Barracudakid has what you need.
Randy Miller
I'm really not sure? All of it was missing. I have two chrome corner pieces only. Look like the lower corners on both side? Any help would be appreciated. I have never rebuilt a Dodge, doing it for a old teacher friend of mine. Thanks
HemiSSDart
Dartus Interuptus
Illinoisy
Yes, most 67 parts are one year only. There was a plastic lock strip with imbedded tin in the top, bottom, and sides with 4 stainless corner pieces. You can find them on eBay.
Randy Miller
That explains it then. When I took out the broken window that plastic was black. Thanks
Do you know where I can find that plastic strip material?
Randy Miller
This may help.
So, on the drum brakes, you're looking for 8 wheel cylinder plungers, #22: View attachment 1715696432
Awesome. I finally found the plunger at OReillys. I search for awhile and though I had to source them from a junk yard. On my way now to completing that part of the project ... now to the front brakes. Hope the drum and parts are the same???
4spdragtop
CONGRATS NORTH AMERICA!
Wasting time here
Precision Replacement Parts is the only mfg for that front mylar/plastic piece. They also sell the 4 corner pieces new. @RPM440+6 is a retailer of those on here and he can make sure to get you the right stuff. OR you can change over to SS trim, BUT now you need a new style gasket, trim clips(and installed) to hold the new SS trim. Obviously the ws would have to come out to do this.
Oh and the front SS trim is available new also. Another reason to lean towards 68/9 style ws trim. I'm eventually doing that on our 67 cuda
cosgig
MoBro Inc.
Pinckney, Michigan
What size drums? You know that 9” don’t have the plunger at all, and only an embossment on the back of the shoe itself that the piston presses against?
