Nite Moves
Im trying to finish up little stuff now on my 67 Dart. I have a power brake set up. I noticed my brake pedal has some play like its lose. The bolt that goes through the pedal lever to the push rod that goes out the firewall seems good and tight. Dose that bolt go in one way or does it matter?????? I have it so the head of the bolt is on dr. side and the nut on pass side..PITA to get in and tighten. Thanks and im sure its a easy question.
