cybrtygr32
1967 Ratfish Fastback
Okay guys, I hate to ask a question on here that has been beat to death, but I searched and couldn't find what I needed (on brake pedal push rod), so here it is:
Going to install a 73 Duster Power Master Cylinder (no booster) with 15/16 bore on my 1967 Barracuda Fastback. Will the existing brake pedal rod on my 1967 Barracuda mate to the larger master cylinder? I have also seen great discussion on which brake hose to use. I haven't purchased them yet. Calipers are on the front of rotors and the 67 Cuda has the brake line mounting bracket just rear of the rotor on frame ( I know you all knew that). Will the stock 1973 Duster hose work (long enough)and not bind up on lock to lock or rub shock area ( I haven't purchased any yet)? Thanks in advance for a reply, you all are a wealth of Mopar knowledge.
