With my upgrade now to the Wilwood MC and the Wilwood proportioning valve the stock pressure switch will not work, it is different threads. The Wilwood prop valve comes with a switch to activate your brake lights but I haven't found enough info as to whether it would work as the idiot light, its also a 2 wire instead of a single wire. What switch are others using when going to a different style - I have not anything found here on the site and googling hasn't gotten me anywhere, below is the stock switch, thread on the new prop valve is 1/8"X27 npt - not sure what this even is. Car is a 69 dart GT, original all manual drum brakes, not sure if the stuff in the car is original or not
switch
crap switch was in
switch
crap switch was in
