[SOLD] Brodix B1BA Heads , Used
Mopar Sam
Well Fed Member
Indiana
I have a set of used Brodix B1BA smallblock heads . I bought these off a Moparts member awhile back. They have been sitting ever since , so it is time to sell . I have the rocker stands, but no shafts or rockers for them. They need a good cleaning before use.The pictures make them look cleaner than they are. The previous owner said he was running a hydraulic cam,and they have single valve springs. Located in sullivan IN 47882 $1275 shipped to continental U.S.
They are standard exhaust bolt pattern, but the lower part of the flanges that connect the outer tubes to the inner two tubes will need removed to clear the relocated spark plugs .
http://www.brodix.com/heads/ford-mopar/b1-series
Part Number Valve Size
0.200
0.300
0.400
0.500
0.600
0.650
0.700
B1 BA 2.080 Intake
129 180 221 249 263 267 269
1.600 Exhaust
119 160 182 190 195 196 198
B1 BA
(Ported) 2.080 Intake
145 203 250 286 300 302 303
1.600 Exhaust
121 169 195 208 214 216 217
B1 BA MC
(Ported) 2.140 Intake
147 216 272 309 332 341 347
1.600 Exhaust
120 170 198 210 215 219 220
Sorry, having difficulty making it look readable to you on my phone.
Pishta , these heads can use either shaft rockers or small block chevy rockers. The bolts are closing off the holes for the screw in studs. I will have to look, but I think they would only be needed on the ones above the intake ports.
Rumblefish, thanks for posting the flow #s.
