Broke a bolt, any suggestions?
standup303
Colorado
Broke the pin/bolt holding in the “main”pin. No room to drill it out. Thinking of drilling the main pin to break the bolt then I can pull the whole diff out and drill/tap a new bolt.
Any other suggestions?
Get a STRONG magnet and stick it in there and pull it out.
Chances are (and the approximate length of the pin/bolt seems to confirm this) that it snapped at the carrier/main pin interface.
Spin the carrier around, use a large drift and a BFH, and I'll bet you can drive that puppy out (the main pin, that is) bringing the remains of the snapped pin with it.
I just had a similar problem with broken bolts in my V10 truck engine. I was able to mig weld a nut on the broken stud, let it cool a minute, then used a wrench/socket to fit the nut & remove the broken studs that way. It worked like a charm, & the broken studs were in the aluminum thermostat housing that was seized in place from galvanic corrosion. May work for you if you have the room.
If you try to drive the pin out be careful, I've see a couple guys set the pin on center then drive the pin straight into the pinion gear... A minor problem just got allot worse....
So, the best approach I've seen, drill a series of small holes in line with the bolt, next go back and open those holes to 5/16.... Then drive the cross pin in but make sure it'll clear pinion, You don't have room to drive the pin in very far so dig out the broken bolt then pull the pin...
I would carefully grind out the end of the Center pin push it out then remove broken bolt , slot the Center pin so not to damage the broken bolt .
