bOb shingler
why run lash caps? I say because of the friction of rocker arm to valve tip. I suggest you get rid of the aluminum shaft hold downs and get steel ones. you can see the bolts are eating into them. I had a shaft break because of that same set up you have. I also agree with you on getting titanium retains. also get the heavy duty shafts, way thicker walls.
