when removed the electric plug from behind the cluster, one of the pins in the circular plug came off with the plug can it be soldered or is it time to look for one???
I had the same problem, no dash lights. That was the only pin on mine that was broken. Fortunately the pin was still in the female socket in the plug. I soldered it back on to the circuit board. Have to make sure it lines up with all the other plugs so that when you replace the cluster and reinstall the plug that it doesn't break off again.
