I bought a set of magnum R/T heads and took a bit of a gamble on them. A couple of the holes for the rocker studs have been drilled and heli coiled. That didn't seem like too much of a problem. But one of them is broke completely. The remaining hole in the head is about an inch and half deep,and threaded. Is it possible to have the part welded back on and run longer studs? Or is it possible to swap to shaft mounted rockers, which seems like a downgrade. Or did I waste my money?
I'm just about finished up with my slant 6 to stock 5.9 magnum swap and I'll be happy with the power for awhile. But heads and a cam are in the plans.
