Buckets seats question
moparstuff
A- body norway
Brumunndal, Norway
Is the frame work from 70-76 Dart,Duster the same ?
can I use buckets seats from 74 duster and seat cover from 72 duster?
I don't think so because of the 70-72 has a plastic back while the 73+ doesn't have the plastic backing.
Depends on the foam used. most A Bodys will accept the plastic back. I have a set of seats from a 75 Cordoba which do have the plastic seat backs but need different foams. The tracks also needed modification. Basically the seat frames are very close needing only new foams or slight modification. If the proper seat foams are used on a 74 they will accept a 72 skin or cover. Hope this helps.
