Build Date?
SSSN8KE
Ontario, Canada
Hey everyone!
Is there any way to tell what day a car was made if all the info known is that the vehicle was the 280,423 car built in 1968.
Thanks for any help you have.
Stu.
It was on the appraisal. Is that not an accurate number?
Well that number you posted is usually on the fender tag near the SPD. (Scheduled Production Date). Is that the last 6 of your vin on the title? If you don't have a fender tag that number if it's the same as your vin is probably the source from your appraisal.
Yes it’s the last 6 on the VIN. Thanks for your help
The motor is not original to the car
Ok although even if it was there's no definitive way of knowing the build date. Typically 2-3 months after the motor is built the car is scheduled to be built.
Hey everyone!
Stu.
Check the stamped number on the radiator support. The first three is assembly date.
